Whooooo hoooooo :party:I figured it out, with all of your guys help of course, I was looking at the relays in the instruction manual and noticed that a finger on the bonus relay is what triggered the 10, 100, 1000 point relay which in turn set the ball count relay, sooooo when I took a real close look I found there were 2 wires that had come loose from the back of the Bakelite on the unit, I soldered them up and the ball count worked as well as the tilt issue. I then had an issue where it would go into two player but score the one player, the instructions showed that a finger on the ball count wheel set the two player, when I looked I could see that the finger was way out of adjustment. Anyway I am good now, everything is working awesome! You guys are awesome, I am buying another one as soon as I can.
