Hi WhiskeyTango
in this post I only look at the "stepping down the bonus ladder and at the same time making some thousands of points". Actually there are two (Sub) Features running parallel / at the same time. So the result in a running pin is "as many bonus" - "as many tousands of points added".
The ball is lost and then the pin makes the Bonus-Relay pull-in - it stays pulling until a switch opens when the Bonus-Unit reaches Zero-Position. The constantly pulling Bonus-Relay makes the Score-Motor run. See JPG
Sub-Feature-1, top of JPG: On the Impulse-Cam the switch IMP-C (marked green) pulses, fires shots of electricity to "Bonus-Unit-Reset-Coil (so the Bonus-Unit steps down and down).
Sub-Feature-2, a bit below in the JPG: On the Impulse-Cam the switch IMP-D (marked brown) pulses, fires shots of electricity to the 1000-Point-Relay.
Want to practice "reading schematics" (?) - in the last ball we are rewarded "DOUBLE Bonus" --- the Bonus-Relay is made pulling AND the Double-Bonus-Relay is made pulling --- see that the stepping on both features are done "in another way" (?).
I like my Space Mission --- when I am troubleshooting and for some reasons I NEED a "Turn" of the Score-Motor (((in Williams and Bally pins: Half a revolution, Gottlieb: A third of a revolution))) --- I gently press and let go the topmost switchblade on the INDEX-Wheel sitting next to the real motor. Want to try (?) --- Wear rubber gloves (insulation , Safety Reasons) --- have a game started - pin is ready to play a ball - now press down (in the pin) the mentioned switchblade and let go --- see the motor makes a turn. Greetings Rolf
