The Sorcerer I acquired earlier this Summer is coming along nicely; however, I have two tech problems that have yet to be resolved. I am hoping that someone with more experience than myself might nudge me in the right direction.
The first issue is the right jet-bumper. Contact with the switch will score points, but the coil will not fire. If I apply ground to Q83 the coil fires fine. Is this a bad transistor at Q83, or is it upstream from there? I’m not sure what to try next.
Issue number two is with the two flashers in the center island with the Sorcerer bank. They will light up at power on and stay lit. When I run the solenoid test, they will flash slightly brighter, but not turn off. All of the other flashers are performing as expected. I have removed these two bulbs for the time being.
I’d welcome any suggestions.
