Greetings from the UK! I bought my first pinball just before xmas 2016 and its in generally working condition, I have replaced the odd coil and bulbs etc. The problem I have is with the score reels, the hundred score reel will always score correctly when playing but at the end of the game if the reel is on 1,2,3 or 8 it will not reset-any other number and it resets ok. I'm not sure if it's related but the thousand reel will not always advance while playing, this is intermittent but the reel always resets!
The ten reel and unit reel have no issues at all, I am pretty handy and I have stripped both reels down and cleaned them with alcohol put back together and it has made no difference whatsoever..........could it be an adjustment that is needed? I don't want to start messing about with it and make it worse. When you manually pump the score reel they are very easy and there isn't any drag or sluggishness. Any pointers would be much appreciated.
Thanks in advance. Richard
