So, a friend of mine has a 1991 Williams Slugfest. The issue is that none of the outfield switches are working during gameplay or in test mode. This includes switches 41-47 and 61-63 and also switch 51 for rear ball trough.
All hits register only as foul balls. Switch 61-63 are only ones showing up in test report.
I have checked the following:
1. Continuity from switches 41-47 to Driver Board (OK)
2. Continuity from switch 51 to Driver Board (OK)
3. Switch Edge test - none of the aforementioned switches register. Test report only shows switches 61-63.
4. Checked all plugs at driver and mpu (OK)
5. Grounded flasher solenoids at Q38, 40 and 42. Nothing happened.
6. Inspected LM339 at both opto boards, all looks normal.
7. Ran tests for stuck playfield switches, all look good.
8. Checked all fuses, all are good.
9. Checked all wire harness connectors, all look good.
10. Checked for voltage at 41-47, all show 12 volts.
11. Rigged 51 closed and then it showed in test report.
What else am I missing? Any theories out there as to what could cause all of these to go down?
Thanks!!
