(Topic ID: 236614)
Williams Shangri-La 1967 normal startup but no game reaction
By GTV6
5 years ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by GTV6
#1 5 years ago
Hello, somebody could give me a direction please?
Startup sequence looks normal. Decrasing a credit, motor turning, resetting scores, relaybank resets, shooting ball in shooting lane. But then when I shoot the ball, nothing happens: no bumper or slingshot reaction, no outlane switch or rollover reactions, flippers not reacting, ball drains and ready for next player.
#2 5 years ago
Game over relay with a closed switch.
#3 5 years ago
The Ball Count unit might need adjustment. It may not be lined up correctly. Does '1' show on Ball in play?
#4 5 years ago
There are two switches that can cut one of the power rails to much of the game
One is on the Game Over relay as @phil-lee suggests, the other is on the Reset relay. If either of those isn't closing or is dirty you might see the symptoms you describe.
There's a schematic on ipdb.org too.
/Mark
#5 5 years ago
Game over relay looks ok, but I will check better tomorrow.
Ball count works fine.
#6 5 years ago
Sorry guys but I checked the reset and game over relays but they seem to work fine. Maybe another symptom: when I begin a game, after the ball drain, the ball shoots back in the shooter lane but ball 1 stays on. Player lights (1up, 2up,...) don’t work (but that was already when I began working on it and it played normal). When I manualy activate the ball count unit, the game goes on to 2nd ball, etc. to game over.
The problem began when I had a shortcut: the spring that turns the coin unit lost grip and touched a wire of the coil that resets the ball#. I had to change the fuse for the 24v circuit.
Already thanks for your help.
#7 5 years ago
Quoted from GTV6:
When set up for a 1 player game, If the Ball Count Stepup solenoid doesn't activate, Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
#8 5 years ago
Ok, HowardR, the red-white wire between coin unit and ball count step up coil is bad. Will solder it now.
This don’t solve the other troubles, but this is a step in the good direction.
#9 5 years ago
Quoted from GTV6:
You're welcome
Quoted from GTV6:
Inspect and diagnose this circuit with Alligator clip jumper wires,
#10 5 years ago
Well, still stuck on the same place. The wire i tought was bad wasn’t. I putted the crocodile wire on the wrong wire. Wires are old and dirty. Very difficult to find the wires between r-w, r-y, etc.
I found out that the Ball index relay doesn’t activate by itself. That’s why there is no ball count after ball drain. If I push the ball index relay it locks, I simulate a ball drain and the ball count stepup coil works, then the ball index relay unlocks.
But... everything came the same moment.
What’s not working: ball count, bumpers, rotating switch, roll overs, outlane switches, slingshots.
What’s working: gi, start up sequence, resetting scores, credits incrasing and decrasing, ball shooting to shooter lane.
#11 5 years ago
Quoted from GTV6:
Check these two make/breaks. Both lead into that relay.
#12 5 years ago
Quoted from GTV6:
To me this sounds like a playfield Jones Plug hooked up incorrectly or dirty/damaged.
#13 5 years ago
Hi GTV6
the ipdb schematics shows at 21/22-F/G (on page 5) a switch on Tilt-Relay - controlling a lot of stuff on the playfield - but not the kicking-out of the ball. See my JPG - the bank of relays mounted on the underneath side of the playfield --- this bank is resetted in the end of the start- / reset-procedure (and also when stepping to next player / next ball). The Tilt-Relay is the rightmost relay in my JPG - all good in Your pin ? Greetings Rolf
0Shangri-La-Relay-Bank-medium (resized).jpg0Shangri-La-Relay-Bank-medium (resized).jpg
#14 5 years ago
And we have a winner!!! Thank you Rolf. The tilt relay it was.
Thanks to all of you!!!
This page was printed from https://pinside.com/pinball/forum/topic/williams-shangri-la-1967-normal-startup-but-no-game-reaction and we tried optimising it for printing. Some page elements may have been deliberately hidden.
