Quoted from MarkG:Keep in mind that some switches like standup targets and kicker switches often have a metal spacer blade between the two blades of the switch. The spacer is meant to adjust the gap between the switch blades but it can short them together too even if the contacts appear to be open.
/Mark
Huh. Yes, I did check that each switch on the playfield was open and not stuck on. In fact, I can get these switches to score before the 1pt relay hangs up. I have not taken them apart, though. I do have other issues going on, but was trying to start here. Maybe I need to start with these issues:
1) Both the top and right pop bumpers get stuck on when activated. It is not the EOS switch. I can see that even without the coil connected the pop bumper relays both stay activated.
2) I have tried disconnecting the 1pt relay and the pop bumpers behave the same way - i.e. they get stuck on.
3) The other two pops are fine.
4) I have a start-up issue as well - the outhole relay is not firing when the outhole switch is activated. In fact, activating the switch cause the score motor to START moving, but it stops right away, the switches just getting out of the indentation in the index stack. I checked the swtiches (both score motor and outhole relay are in this stack on a make/break switch). I can't find anything wrong with these either.
I have checked the outhole relay works.
i have checked the outhole switch works.
So, ready to figure some things out. Sometimes these complex problems are just one switch and everything else resolves. Just need to find it.
