Alrighty! So I'm almost finished reviving an old Scorpion pin. The last big issue I need to tackle is with the pop bumpers which suddenly went haywire. Scorpion has 3 pop bumpers and the bottom one works fine. The right one will lock on when I either try to start a game or when i enter solenoid test mode. The top bumper will start and stay on as soon as i power up the machine. They were all functioning properly a few days ago so the wiring should be correct. I tried re soldering the wires and testing the diode and everything looks fine. I have to turn off the game as soon as I start it now or else I keep blowing the F2 fuse(solenoid).
Using a DMM I probed the blue-brown wire for the top bumper (should be connected to the driver board 2j12) and it is grounded all the time. I dont think that's right? I thought bumpers were supposed to be on all the time and fire(short) whenever the switch is activated. I looked at the switch and it is open so I don't know why the blue-brown wire is grounded.
On the right bumper I have no idea why it locks on during the solenoid test (right as it enters test mode) or whenever a new game is started. I haven't probed yet but I can assume it has the same issue with it's driver wire where it shorts the wire when the game starts and doesn't wait for the switch. Are pop bumpers special solenoids and function without waiting for the driver board?
Also it should be noted that in order to get the game up and running properly I swapped the MPU and Driver board with a rottendog MPU327-4 combo so the wiring is slightly different from a stock board.
As of right now my only inclination is that something is wrong at the actual bumpers but I can't see it. Ive been looking for maybe some stray solder that is bridging some connections or a loose cable but I'm losing my mind over this. Do you think I maybe blew a transistor on the new board or are one of the IC's acting up? What would I look for with a logic probe?
Thanks for any help!
PS: Is there a site that has manual/schematic information for pins? I have a couple old/original/cool diagrams and information about Scorpion that I haven't seen online and I'd be happy to share.
