Hi amymcg
the big difference / question is "is it weekend or not ?".
There is only one way to place a jumper - to place it exactly as shown on a JPG. If there is no room to clip-on the gator-clip where mentioned / drawn ((( the clipped-on gator-clip would also have non-wanted, faulty connection to neighboring solder-lug))) we then must talk and find a way to do "alike test". See the first JPG "marked green jumper, green question-mark" --- we better do not communicate in such form - If I would write "do marked green jumper" - You would have to ask "WHAT exactly shall I jumper ?". See at the bottom of the first JPG the AA, BB, CC, DD - FOUR different ways to set a jumper.
Top-AA, Top-BB, Top-CC are exact implementations --- IF (if,if) it is impossible (not room enough) to clip-on at "Switch-on-Score-Motor-Index-Cam-Position-A-Switch-Solder-Lug-on-blade":
An alternative way to Top-AA is Bottom-AA --- as wire-30-yellow runs in the pin to "Switch-on-Score-Motor-..." and wire-30-yellow also runs in the pin to "Switch-on-Lock-Relay" O.K. - O.K. - we would like to do "Test Top-AA" - as a compromise we do "Test Bottom-AA".
An alternative way to Top-BB is Bottom-BB --- clipping on at solder-lug-wire-73-1-orange-yellow on a better-to-get-at-place.
An alternative way to Top-CC is Bottom-CC --- clipping on at solder-lug-wire-73-1-orange-yellow on a better-to-get-at-place.
See on bottom-right corner of my JPG - "EE" - in a way one or two or more pieces of wire-73-1-orange-yellow do connect many solder-lugs on different relays / switches.
Me and You - we both must know exactly what place to clip-on / have clipped-on - otherwise me or You or we both get confused / led astray - make wrong conclusions.
In Your post-23 You write " ... with the jumper in place ... " - question: Is the jumper set like "My JPG here, Upper-CC" ?
I would like to change strategy - I would like to follow the hint sudsy7 he made in his post-9 --- the Coin-Relay in San Francisco must stay pulling longer then in many other, newer Williams pins.
See my second JPG - some stuff I may want to talk about later - for now look on the bottom-left corner, the Coin-Relay: Wear rubber gloves - toggle-off the pin - then toggle-on the pin - then with an wooden stick activate the armature on Coin-Relay - (simulate coil gets current and pulls) - keep-on pressing the armature , activate, activate - let the motor do his turning - about 2 to 3 turns of 180 degrees - when the huge bank of relays in the bottom of the cabinet (nearby) resets - then let go on the Coin-Relay (no more pressing / activating) - what do the Score-Drums do ? what does the Reset-Relay do ? Greetings Rolf
