The left pop-up on my Space Mission does not score. The right one works fine. Comparing the two, I see where a leaf is missing from what is likely called the scoring switch. The manual I have says the switch is A-7459-2 part number. I'm assuming the part number has changed over the years because I see A-7459-7 listings. My problem is that I can't find either one in stock with the vendors I normally check. Any suggestions?
(This is all assuming I have to replace the whole switch and not just the missing leaf.)
