(Topic ID: 220345)
Williams playfield lights not working
By Deceptacon45
5 years ago
#1 5 years ago
Hi, I am working on a 3 coins and have no playfield lights. I do have backbox lights and the game seems to work fine, except no gi lights. An anyone help, please. Thanks.
#2 5 years ago
I'll need to see a high quality scan of the schematic from (for example) Staples ($2) or Kinkos ($6)
#3 5 years ago
I'm so sorry, I do not have the schematics. Tried looking for them online but to no avail.
#4 5 years ago
Quoted from Deceptacon45:
Check switches on the lock relay. Might be called hold relay.
#5 5 years ago
pbresource.com or marcospecialties.com may have it. Did you try them?
Also, the other owners may have it.
https://pinside.com/pinball/archive/3-coins/owners
#6 5 years ago
There are schematics for Trade Winds and other games made around the same time on ipdb.org. The Trade Winds schematic shows that the backbox and playfield have separate fuses.
If your game has the same configuration you could have a bad 6V playfield fuse, or a bad fuse holder.
/Mark
#7 5 years ago
Thanks for all the info, I will look into those areas and report back.
#8 5 years ago
check for loose or broken connections at the jones plugs.
#9 5 years ago
Hi, I checked the fuses and the fuse holder, seems good. Also looked at he switches on the lock relay, that also seems to check out. All the jones plugs have good continuity, no apparent loose connections there. Still no lights.
#10 5 years ago
Trade Winds, Reserve and possibly other games from this era put many of the playfield lights through a Make/Break switch on the Tilt relay:
3 Coins playfield lights (resized).jpg3 Coins playfield lights (resized).jpg
In Trade Winds the wire colors are 51/white-red, 50/white and 95/gray-white. Do you have a similar switch?
#11 5 years ago
Hi all, I got my problem fixed, turns out it was a bad solder joint on the fuse block. It all works fine now, thank you all for your help.
This page was printed from https://pinside.com/pinball/forum/topic/williams-playfield-lights-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
