We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 260970)
Williams Planets keeps cycling
By RandyW
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 10 months ago by RandyW
#1 1 year ago
I am working on a Williams Planets that when you start a game it will keep cycling, like it is looking for the ball. When you get it to catch and start a game, once the first ball is drained, it starts cycling thru the balls again. EMs are NOT my strong point and to be honest, I am not sure where on this machine to start looking.
Any suggestions?
#2 1 year ago
Ok it could be a misadjusted switch start with the drain switch and see if it properly adjusted.The most problems that occur with EM’s are switches.
#3 1 year ago
There's a schematic on ipdb.org:
There are nine different normally open switches that connect to the orange-green wire that sends power to the Score Motor. Any one of those switches being closed or shorted could cause the motor to run. Check each one visually to see if you can tell which ones are closed. If that doesn't help block the switches with paper to see which ones when blocked will let the motor stop. One of the nine switches could be the problem or it could be the relay that's closing the switch that is the problem. Either way you need to figure out which switch is closed.
/Mark
#4 1 year ago
Thank you both very much! EM's are my weakness. I have been trying to buy a couple cheap ones, to mess with in my free time, but you know how that goes
This gives me a good idea of what to look at when I go back to it this weekend.
3 months later
#5 11 months ago
I finally got a chance to spend some time on this planets table. When you start a game, it will usually run thru all the balls in a row. Like it says balls one, then before you do anything it cycles through to ball 5. Sometimes it will stay on ball one, sometimes it will cycle to ball four and stop. It seems pretty random. The only things I can find currently that are an issue, is the lock relay coil is burnt up and broken.. but oddly still works and the contacts on the bakelite for the ball count unit seem heavily worn, with a visible groove. However, I seem to have continuity everywhere on that. I'm going back in a couple days, when I get parts in for another of their pins.
#6 11 months ago
I have Zodiac, which is the same thing as Planets except that Planets (the add-a-ball) is even more rare! We like ours and play it a lot.
Switch #2 on the score motor, a switch on the Tilt Relay, and a switch on the Outhole Relay each could make it step from ball to ball if it's adjusted so it can't open.
The second picture shows the Tilt Circuit - the plumb bob, the ball tilt (next to the plumb bob, the smaller rolling ball that keeps you from lifting up the front of the game) and a slam tilt switch could all be making it tilt and move to the next ball. Does the "Tilt" light on the backglass flash on and off as it cycles through the balls? Let us know what you find!
#7 11 months ago
Quoted from DCP:
Thank you for that! I do not remember seeing the tilt light come on. But I will definitely check for it when I am back there this week.
4 weeks later
#8 10 months ago
So the problem turned out to be a nut had dropped between the game over relay and the Tilt relay and was down so low I couldn’t see it.
I would have never found it without your help so thank you very much.
