I ordered and received a new tube and tube holder from tube depot. I also ordered and received the new cartridge from voice of music. I am going to cut the original cartridge in half so I can mount the modern low profile cartridge in the tone arm using the original holes.
When I was transplanting the amplifier from its original long steel mount to the new mount I had made, I broke one of the tube plugs. I was drilling the 70 year old tube holder/plug to accept a 1/8" rivet and the drill bound. The bakolite was broken. Uncertain if it would work , I mended the part and installed it.
I ordered a NOS holder and a new tube even though I was sure the tube was good. The problem was that the broken mount simply would not hold the tube tight. Between the heat of the tube ( yeah they get freaking hot!) and the movement of the record changer and steppers the tube would work its way out and I would lose sound. Changed the holder and the tube. Added a molex plug to connect and disconnect the amp from the tone arm. I also changed the scary power cord. I never buy those brown cords so I had to cut the cord off a clamp light I had.
