You sir are amazing, with your wealth of knowledge . My left gate doesnt work so you are absolutely correct.
Here is what I found.(listed below) The seven segment led is a dead giveaway.
Would it be considered overkill to just replace all the transistors? I think I counted 60 ish which would only take me about an hour to replace.
Per the bulletproofing section I figured I would go ahead and replace the CAPs as well, along with adding fuses to the bridges and replacing the battery holder with a 3f CAP. I think I would probably be out around $70 for all the caps,transistors,fuses etc... Worth it?
Also where is a good place to get the 3f caps? I found most stuff on Great Plains but, the 1n5243 only comes in rev B which is double the voltage recommended ie. 6.3v vs 13v. So I will probably need to source those elsewhere.
Either way, thank you for your wealth of information and I am already compiling an order. I'm overly eager to get this machine back to life. Right now everything powers up sounds good but, its like a man with no arms at a clapping contest. Just pitiful really.
System 11 CPU board.
Part number D-10881. Uses a 7 segment LED on the CPU board to display the game's diagnostic codes. This version of system 11 contains the amplifier circuit for the sound board. It also has a complete, but unused opto switch circuit.
System 11A CPU board.
Part number D-11392. Uses 3 LED's to replace the 7 segment LED for the game's diagnostic code display on the CPU board. The special solenoid circuit is changed; jack 1J18 now has ground connected to pins 6,7. Also zener diodes ZR3-ZR8 (1N5234, 6.2 volts) were added. Finally jumpers W16, W17 were added to ground pin 38 of the 6802/6808 microprocessor U24. If a Motorola microprocessor is used, W16, W17 must be connected. If any other brand of microprocessor was used W16, W17 must not be jumpered.
