I was bored and jumped on the first EM I had seen advertised in awhile for a decent price. I took a cursory glance at the back glass and play field and the deal was done.
It showed 14,690 games total and I believe it. No nicotine haze, all steppers show Factory grease hardened tighter than "Dicks Hatband". IMG_1793 (resized).JPG
All 6 received "The Treatment", complete cleaning and lube, though the combination of grease from hell and tightly machined parts that had never been disassembled required hours of manipulation to avoid damage.
Plastics were in good shape graphics wise but exhibited the characteristic "Cup" since Williams employed the plastic as support for the post and rubber ring. These will be flattened.IMG_1786 (resized).JPG
I used an old heat gun and 2 sheets of heavy picture frame glass.
Every switch on every relay was cleaned, tightened and adjusted on every board,sometimes twice. Several stray wires were found loose and soldered that were missed the first time. Clean and light grease the motor cams, target motor gears, slingshot/shooter mechanisms and ball serve apparatus.
The back glass was in remarkable shape save a nasty loss of blue and white on Widows' hat. After trying to duplicate it finally scraped the paint off and installed photographic gel material backed by translucent white.
I cleaned the play field first with Coleman fuel, then liquid Barkeepers friend, afterwards 3 coats of 100% Carnuba. Lot of rubbing and buffing by hand. No need for touchups and very fine planking in certain areas.IMG_1829 (resized).JPG
