I have a 1975 Williams which the match unit armature sticks to the coil.
I have come to my wits end, I have no idea what is causing this. The coil is pulsed on, pulling the armature to it. Power is removed from the magnet and the armature remains stuck to the coil pole.
I can reach around with my finger and with just a very slight touch on the backside of the armature and it pops loose from the magnet pole. It's like the armature has sticky adhesive on its back side.
I've disassembled this unit 3 times, cleaned the armature backside and coil end-pole with alcohol and gave it a light sanding. The last time I reassembled it, I increased the return spring pressure and it worked properly for maybe 30 games or so and it's back sticking as shown in the video.
I have also tried adding various width shims (washers) between the coil and match unit frame, where it mounts.
The first thought is it may be hanging up on the ratchet, but you can see I can slowly rotate the ratchet shaft, even clicking the pawl which shows it is not a mechanical ratchet bind.
The first part of the video-
I rigged a yellow wire clip which I connect to the 24v buss for testing. You'll see me start a game and activate the relay- then release it with my finger.
The second part of the video-
I thought maybe something was keeping the coil energized so I rigged a 24v lamp and clipped it onto the coil terminals. It shows nothing is keeping the coil energized and rotation of the ratchet shaft.
Any ideas at all? I am dumbfounded and I need to get this fixed.
Thanks in advance.
