Williams Lucky Ace 1974 - 10s score reel not resetting
The other score reels reset OK, just not the 10s reel
If I manually move the 10s reel to 0, the game starts OK
Thanks,
RussMyers
Thanks,
RussMyers
Assuming the 10 point score reel will score points during a game, but it won't reset when starting a game. Then you'll need to look at the circuit that sends power to the 10 point score reel solenoid during the reset process. Check the following switches:
Score reset relay switch - switch with yellow wire and black/red wire
10 point score reel zero position switch - switch with black/red wire and orange/blue wire
Check to make sure these switches are clean and adjusted properly...
I can't get the coil on the 10s reel to fire at all. May be a broken wire internally; I found a mount screw that was too long sticking into the side of the coil.
Sigh.
RM
Quoted from RussMyers:I can't get the coil on the 10s reel to fire at all. May be a broken wire internally; I found a mount screw that was too long sticking into the side of the coil.
Sigh.
RM
Put a multimeter on the coil. It should show a resistance around 6 ohms.
Quoted from EMsInKC:Put a multimeter on the coil. It should show a resistance around 6 ohms.
Yeah, did that. It's OL - open circuit.
RM
This page was printed from https://pinside.com/pinball/forum/topic/williams-lucky-ace-1974-10s-score-reel-not-resetting and we tried optimising it for printing. Some page elements may have been deliberately hidden.
