Nokoro is on the right track here, I'm guessing it's a broken wire or diode at any of the 6 switches of row 8. Here's the row of switches shown on the schematic: 2045805753(1).png
Note the wire color for that switch row is white-gray. This means you want to find each switch on row 8, and make sure that the white wire with gray stripe is firmly attached to the solder lug on each of them. There will be multiple white/gray wires at certain switches because the circuit "daisy-chains" from one switch to another switch on its shared row. I made a little red mark next to each switch in the row: 16,24,32,40,48,56 1818734574(1).png
Gently tug the white/gray wires at each of the 6 switches marked above to be sure they're firmly connected. You may find one broken off already...if you do, you found to problem--solder the wire back onto the correct switch lug. Next check the diode on each switch. Make sure the diode isn't touching anything it shouldn't be, and that it's also firmly connected at both solder lugs on the switch.
If all the wiring and diodes are properly connected, next I'd verify you can get continuity from every white/gray switch wire up to the connector at the mpu J3, pin 1 (which is that same white/gray wire, just where it leads up to the mpu). If continuity is good up to there, you may have a bad solder joint or header pin at J3 on the mpu or another problem with the mpu.
