(Topic ID: 323714)
Williams Laser Ball "Ball in play" display goes blank when game starts
By mvec
1 year ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Mikala
    #1 1 year ago
    Hi, I have a Laser Ball pin and the "Ball in play" display goes blank as soon as I press the start button. It was working correctly, but just stopped.
    not sure if it is a bad display driver or bad display...or a wiring issue. Does anyone have experience with this? Thanks
    #2 1 year ago
    I would look at your connections first.Check for a loose wire or pin on the connectors on both driver board and mpu output.
    I upgraded all my displays with wolfpac . I highly recommend them.
    It's hard to imagine it's your display or driver since it works before a game is started. Most likely a bad IC
    Pm if you need more help.I have the schematics.
    #3 1 year ago
    Quoted from southofi-10:
    It is definitely a loose connection somewhere because I started it up yesterday and the display was on, but flickered a while then went out again.
    If you could point me to the schematic that shows where I need to look that would be great. Thanks
    #4 1 year ago
    Try this--before power up,disconnect display 1,Power up..If no change,reconnect and disconnect display 2.Keep doing that making sure you power down before plugging or unplugging a display. I think you may have a bad display,and this is a good way of finding it.
    I recall the same problem with my LB and it was a bad display effecting the ball count/driver board.
    Report back please.....or send PM.I have game and schematic.
    #5 1 year ago
    You may want to try posting in the Early Solid State forum.
    #6 1 year ago
    You'll get better replies on one of the Solid State forums. This is Electro Mechanical.
    https://pinside.com/pinball/forum/topic/how-to-efficiently-ask-for-pinball-repair-help-em
    #7 1 year ago
    I tried that and it didn't work. I reseated all of the connectors on the cpu board and that seemed to work.
    #8 1 year ago
    This page was printed from https://pinside.com/pinball/forum/topic/williams-laser-ball-ball-in-play-display-goes-blank-when-game-starts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
