(Topic ID: 304942)
Williams Lady Luck beat the dealer no extra ball
By daw6205
7 months ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 7 months ago by daw6205
#1 7 months ago
Hi Everyone,
I need help to resolve this issue with my Lady Luck , If I beat the dealer with 21 points even, I do not get an extra ball. This issue wasn't there before i cleaned all the stepper units and the contact switches. Does anybody out there have the diagram so i can understand where i can start to check and resolve this problem?
Many thanks in advance
#2 7 months ago
You can download the schematic from the pinball database.
#3 7 months ago
Quoted from daw6205:
You sure this is the Bally?
#5 7 months ago
Do both players have the problem? Does the 20 point relay trip when the 10 point card score reel reaches 20 for both players?
/Mark
#6 7 months ago
Quoted from pinballdaveh:
Hi, yes I did it
I've got a schematic,
#7 7 months ago
Quoted from MarkG:
/Mark
Hi Mark, I can't check it now the pinball isn't here with me , it is with my friend that he lives another town. I have to go there to check and fix this issue. Before I'd want to have the clear idea where to check
. Certainly, now when the player passes the 20 card he get not an extra ball
.I already have the Lady Luck diagram and I was hoping that some of you could send me the exact point on the diagram to check.
Many thanks
Davide
#8 7 months ago
This is the path that should give you an extra ball when either player drains with 21 points:
There are nine or ten switches (depending on the player) that all need to close, plus the wiper on the score reel needs to be at 1 and the Replay on 21 adjustment needs to be set the right way for the Extra Ball relay to fire. If you can determine whether or not both players see the problem that would eliminate some of those switches. Or just jumper around a few switches at a time to see if you can pinpoint which switch isn't closing.
I'm curious, did cleaning everything solve any other problems?
#9 7 months ago
Quoted from MarkG:
Thank you so much Mark.
This is the schematic that I needed to understand where I can put my hands.
Yes , another issue I had after cleaning all the steppers was from the stepper unit coin that the step up coil wont fire twice and the BCU wont move from position 1 ( ball 1) to position 3 (ball 2).
Thanks to HowardR, I have already solved this issue.
$ 5.95
The EM Scientist
850
Las Vegas, NV
$ 259.99
Various Novelties
GC Pinball
Great pinball charity
Pinball Edu
