Hello,
First time posting on here.
I have a williams jubilee I picked up not too long ago and have been trying to get it to work. Im pretty logically oriented so I have a good understanding on how ems work. I have went through the stepper units and made sure the contacts are clean and mechanically function and have went through the game and made sure all the switches move properly (active and inactive) states. The problem I am running into is that most of everything works as it should with the exception of the advance scoring process. If either the advance/ 3-advance relays are activated (any advance switch on PF) the 15 amp fuse blows. I have narrowed it down to the leaf switch on both relays that "Energizes advance unit step up coil". I have tested this by only allowing this leaf switch to connect and it blows the fuse. I have manually step upped the advance stepper unit and on ball drain the bonus counts down and stepper steps down back to home pos without blowing the fuse. I am at a loss here as it seems to be possibly a dead short?? Any help would be appreciated.
