Hey guys.....I have a problem with the Flashers on my Williams IJ.
First it was blowing Fuse F111 so I replaced BR4 (bridge diode). Now it is not blowing the fuse but all of the flashers still do not work. I tested voltage with my multimeter and I do not get any voltage on the J102 connector. This connector states 16VAC from transformer secondary. I tested the volts on these wires at the connector by the transformer and get nothing.
Also tested the red wire at each flasher...nothing.
Do I have a transformer problem or is this "secondary" wire loop missing something that will complete the circuit?
Could a new "bad" BR4 create these results?
What should I test next?
Thanks in advance for any tips.
