Hi Indiana Jones pinsiders I need somebody with a Williams Indiana Jones to help me with some measurements so I can drill some holes in the lower cabinet please help thank you
Quoted from jadziedzic:Which measurements do you need?
thanks for your help The two big ones on the right side of the lower cabinet for the playfield hinge and the smaller one on the right side cabinet for the safety bar that's on the inside with the yellow handle and they are two on the left side for the left side hinge figuring the best way to measure is bottom up and from the back forward they need to be dead on what my playfield will be crooked
I measured a number of times and came out with the same values, so they're probably CLOSE; but I would solicit a few more sets of measurements before irrevocably drilling a cabinet. Also double-check the placement of the playfield slide bolts relative to each other using the metal bracket that installs on the inside of the cabinet over the bolt threads (the pivot nuts bottom out on this bracket).
Right side:
Rear-most playfield slide bolt: 19-1/4 from back, 13-13/16 from bottom
Front-most playfield slide bolt: 23-1/16 from back, 12-5/8 from bottom
Prop rod bolt: 36-13/16 from back, 7-15/16 from bottom
Left side:
Both bolt holes seem to about a 1/16th closer to the front of the cabinet (19-5/16 and 23-1/8); if I were drilling them I'd match the positions of the right and left sides.
Quoted from jadziedzic:I measured a number of times and came out with the same values, so they're probably CLOSE; but I would solicit a few more sets of measurements before irrevocably drilling a cabinet. Also double-check the placement of the playfield slide bolts relative to each other using the metal bracket that installs on the inside of the cabinet over the bolt threads (the pivot nuts bottom out on this bracket).
Right side:
Left side:
Thank you for your time.nobody wants to take the time to help. Good idea for me to get more to make sure their correct
Thanks again.
Quoted from Ijpinball:Thank you for your time.nobody wants to take the time to help. Good idea for me to get more to make sure their correct
Thanks again.
? Did you replace the rubber yellow handle I am looking for one and can't find
This page was printed from https://pinside.com/pinball/forum/topic/williams-indiana-jones-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
