I'm working on a Williams Hyperball driver board that has a bad 2N6548 in the lamp matrix. Looks like these are not available. Can someone confirm if a 2N6427 or a MPSA13 is a suitable replacement? Thanks!
Funny - just last weekend I was working on a friends Hyperball driver board and need this transistor too!
Google research says the CEN-U45 is a readily available replacement.
or
Quoted from Schwaggs:Funny - just last weekend I was working on a friends Hyperball driver board and need this transistor too!
http://www.mouser.com/ProductDetail/Central-Semiconductor/CEN-U45/?qs=%2fha2pyFaduj3QKsL6n4fl48Q5Aypro4q00qslnwhi%2fE%3d
or
http://www.marcospecialties.com/pinball-parts/MPSU45
That part # will work but it's way overkill and much more expensive. The MPSA13's are only $.20 a piece.
A friend had a donor driver board that I robbed a 2N6548 off from so I'm set now.
If someone could confirm the MPSA13 or the 2N6427 will work it would be appreciated for future reference. Thanks!
Quoted from debaser:That part # will work but it's way overkill and much more expensive. The MPSA13's are only $.20 a piece.
a mpsu45 or a 2n6549 will work. different package on the mpsa13 not enough switching power.
Not overkill at all. The original part and the MPSU45 and the CEN-U45 are good for 2 amps. The MPSA13 and 2N6427 are not equivalent as they can only switch 1/2 an amp.
Quoted from Schwaggs:Not overkill at all. The original part and the MPSU45 and the CEN-U45 are good for 2 amps. The MPSA13 and 2N6427 are not equivalent as they can only switch 1/2 an amp.
2n6427 is used on wms 3-7 for the lamp column predriver. Is Hyperball circuit different?
Ahh ok good to know. I must have misread something when I was looking into it. The 2N6548 I robbed off a donor board did the trick and my column of lamps is working again.
Thanks for the info!
Quoted from barakandl:2n6427 is used on wms 3-7 for the lamp column predriver. Is Hyperball circuit different?
Yes it is.
Quoted from debaser:Yes it is.
ahh ok... i asked because sometimes i find the high current rated darlingtons in normal wms pinball 3-7 driver boards for lamp columns...
This page was printed from https://pinside.com/pinball/forum/topic/williams-hyperball-replacement-2n6548 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
