I am trying to fix my cousin's Williams Hurricane pinball machine. The Service Credits, Volume Up, Volume Down, and Begin Test Switches are unresponsive. Also the coin switches are unresponsive. The coin insert slots are not lighting up.
I've used a voltmeter to measure across the switches. I get about 12 volts across each switch.
Everything appears to be properly connected. I found a wire pulled out of the connector on the coin door open switch. I also found a pulled out wire on the Start button light. I added new connectors to these and both have been fixed.
Would anyone have any advice on how or what to troubleshoot?
