(Topic ID: 284851)
Williams Hot Line stuck in tilt
By Kmolo
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by ArgosySK
    #1 3 years ago
    Hi looking for some help with a reset issue on Hot Line. Game was playing fine and then ball just won’t push through from trough. Power on game and hit start button. Game will immediately tilt upon any switch register. Ball will not kick out and game keeps cycling. The slam switch on door was corrroded horribly so it was bypassed, seems to do nothing. If I unplug the block still tilts. All the other slam tilt switches are functioning. Ideas?
    #2 3 years ago
    Assuming all tilt/slam tilt switches are open at startup.. Press Start button... GAME OVER relay should trip, and that trips LOCK relay and LOCK should stay closed through its own HOLD switch until end of game or tilt...
    Can you check to see whether GAME OVER relay is tripping? If it is, check that LOCK relay trips and is held in... if that sequence is working, I'd check both GAME OVER and LOCK relay switches for proper open/close operation... tighten relay switch stacks first, clean contact points.
    Report back.
    #3 3 years ago
    Quoted from Kmolo:
    Check this make/break.
    #4 3 years ago
    I agree with both comments. The Tilt and game over lights are controlled by the game over relay and the ball unit.
    Check the gap on the Game over relay and if it is pulling check the gap on the lock relay. The lock relay should pull and stay pulled during the game.
    Schematic found here https://www.ipdb.org/machine.cgi?gid=1245
    If the lock relay isn't staying pulled that will trigger the game over relay.
    Game Over (resized).JPGGame Over (resized).JPGgame over lights (resized).JPGgame over lights (resized).JPG
    This page was printed from https://pinside.com/pinball/forum/topic/williams-hot-line-stuck-in-tilt and we tried optimising it for printing. Some page elements may have been deliberately hidden.
