Hi, I’m trying to bring a Williams Honey back to life. One problem I know it has, has to do with the alternator unit / 5 cent relay. There was no alternator unit coil present; only the mounting bracket. It’s almost as if it were never present, and I’m not entirely sure it’s needed (since this game will be set to free play). The black wire junction that probably went to the coil was floating in the vicinity. I added a coil and connected the black wire junction to one lug of the coil. The other lug of the coil appears to connect to a jumper wire that should connect to a 5cent relay switch (that has a yellow wire on the other side of the switch). The strange thing is that a jumper wire is floating/disconnected in the vicinity but the other end is connected directly to the main yellow wire.
Here is a quick video to show this. It’s a lot easier to show than explain in words. Do you agree that a wire should go from the other side of the 5cent switch to the alternator coil?
