To all High Speed owners and anyone else that knows the answer to my questions:
I am struggling with the two switches on the ramp on my Williams High Speed. Sometimes they fire and sometimes they don't.
My first question is how they are supposed to behave. From my observation it appears that they alternate when you shoot a ball up the ramp. That is, a ball will go up the ramp and the left switch will activate and route the ball down the left wire rail and the next time a ball goes up the ramp the right switch will activate and route the ball down the right wire rail. Is this correct?
Because I am seeing that sometimes the ball just goes all the way thought the ramp and out the other side without going down either wire rail and sometimes it goes down the left side mostly and the right side not so often. This is especially problematic when you "get away" and you are supposed to get three balls in multi ball play however because the right side rarely fires you usually only get two balls in multi ball.
I have run through the switch tests and yes the left side mostly fires correctly and the right side rarely fires. I just had the ramp off and fixed some cracks so I guess I will remove it again and work on the switches.
Any advice appreciated.
Thanks,
Michael
