(Topic ID: 287173)
Williams High Speed Left Hideout Problem
By Blantz59
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by nplg
#1 3 years ago
Hello,
I'm new to Pinside and at a complete lost of what's causing my problem. My Williams "High Speed" has been recently having problems with the Left Upper and Lower switches on the hideout ramp. When I run a switch test it's not recognizing either switches as well has the shooter lane switch, and the engine rev when either flipper is activated. All other switches seem to be fine. All the coils are also firing as well as the left hideout coil when I run a coil test. I have checked all the fuses in the head of the machine and they all test good. I don't see any lose wires or anything else that might be the culprit.
I have tried to find anyone in the central Ohio area that does pinball repairs with no luck. Any help would be greatly appreciated.
#2 3 years ago
You tube has lots of short videos on how to use a meter and also check continuity.
If those switches have a common wire, you likely have a break from them along the way at other switches and to the board in the head.
#3 3 years ago
Thank you for the response. I tested continuity on all the wires to the affected switches and they all test good.
#4 3 years ago
I've seen the large plug from the playfield to the backbox cause problems with groups of switches. May be worth taking it apart, cleaning, and checking continuity from the playfield side back to the main board connector(s).
#5 3 years ago
Quoted from nplg:
Thanks, I'll take a look tonight to see if that's the culprit. I've owned this machine for nearly 25 years with little to no trouble up until now. I appreciate the advice, I really hope that's the cause of my trouble because I've checked about everything else I can think of.
#6 3 years ago
All of the switches you named are on the same "column" (#5, Green-Black wire, 1J8-5, Q43). At 35 years old it is certainly a connection, loose wire in a crimp, or cracked solder joint. Been there on a High Speed I'm restoring.
Once located, the fix is a quick one
#7 3 years ago
Quoted from nplg:
Thanks again for your help. I recently replaced the entire left flipper assembly before the trouble started. Do you think that could have anything to do with the trouble I'm now having? I'm getting ready to remove it, and reinstall it incase I have a cold solder joint or something. The left flipper is working great, but I'm wondering if maybe it's connected somehow. I'm also trying to find which large plug you mentioned in your earlier post. Does that plug attach to the CPU board?
Thanks again
#8 3 years ago
Definitely double check all of the wiring in the area where the work was done. The diagram calls out the wires for the switches in question.
BTW: The "large connector" is on one of the playfield cables. Large, multi-pin connector maybe 24+ pins.
#9 3 years ago
Quoted from nplg:
Thanks again for your help. I'm hoping to go over everything you suggested this weekend. I really do appreciate your help because not knowing the cause is very frustrating.
#10 3 years ago
Quoted from nplg:
I re-wired the left flipper assembly and now I have a new issue. When I run switch test I'm getting message saying problem with 11 (Center Trough) and 12 (Right Trough) errors, and still having the original switch issue. I'm going to need to find someone that does repairs in central Ohio because I'm concerned about possibly doing more damage because my eyes aren't as good as they once were. Do you know of anyone in central Ohio that might be able to assist me with this?
#11 3 years ago
I can do it. Send me a direct message and we can discuss details.
RobTune
$ 35.99
RobTune
$ 18.00
Volcano Pinball
RobTune
Metal-Mods
$ 18.00
$ 2.50
$ 30.95
Fort Lauderdale, FL
$ 69.00
Pinball Pimp
$ 53.99
Orange, CA
5,000 (OBO)
Parkland, FL
