Working on a Williams High Speed.
The flippers and special solenoids are active even when the game is just in attract mode.
Its going to be HUO, so is this really as problem? Or maybe this a sign of a bigger problem?
Suggestions on fixing it?
Quoted from PghPinballRescue:so is this really as problem?
Not a big deal.
Quoted from PghPinballRescue:Suggestions on fixing it?
Test U-50, U-56 and SR-19.
Thanks, will do tonight when I get home.
I'm also thinking the relay could be bad (easy enough to test) or the transistor that powers it (also easy enough to test).
Quoted from PghPinballRescue:I'm also thinking the relay could be bad (easy enough to test) or the transistor that powers it (also easy enough to test).
If it was the relay or the transistor then the Special Solenoids would not be active too.
This page was printed from https://pinside.com/pinball/forum/topic/williams-high-speed-flips-and-special-sols-active-in-attract and we tried optimising it for printing. Some page elements may have been deliberately hidden.
