I have a Williams High Speed game that is working almost perfectly. All the music, switches, scoring and coils are working just right. The only problem is when I turn the game on the ADJUST FAILURE warning goes into the top 2 scoring displays. I then have to go into Adjustments and set the game to Free Play - Yes. Then the game works great. But if I shut it off and turn it on the next day the same issue comes up. For some reason I feel that the game is not remembering the adjustments I made. The batteries are lithium and are brand new. I have some issue with the Power Supply Board in that the top 14 or 15 pin connector is a little out or sorts and I need to put a little pressure on it to make it work properly. I know this ADJUST FAILURE is an issue that has been discussed quite frequently but I have read the other Forums and can not come up with the solution. Can someone help me with this pretty common issue. Thank you.
