I am asking for help to get my williams heatwave up and running 2 problems i have noticed are pictured below
2nd picture- i have loud Humming in the first 0 to 9 score wheel and the coil is getting VERY HOT. All the other score wheels reset besides this one apon start up so my question is from top to botton which contacts on the switch stack should be open and which should be closed maybe that would stop the problem with the humming and the Heating of the coil?
1st picture- is of the unit that moves the red ribbon up and down the only way i can advance it past FRIDGID (the bottom) is if when the game is off i manually move it back and forth with the stepper than it can go all the way to the top but when i also try to manually reset it back to the begining it does NOT move any help or tips would be appriciated! Also noticed that the game does not score unless the ribbon is at the start then the game becomes energized enough to score points but it will not go past fridgid once the game is being played only when it is off and i manually acuate the coil back and forth.
3rd problem- it does not show up ball 1 2 3 4 5 on the backglass do the earlier games not do that since they have the rod that kicks the ball up onto the playfield?.
Anyone that owns a heatwave or could get on video would be great as well thank you.
