(Topic ID: 291077)
Williams Grand Prix -- will not activate player 4??
By Carmoney
9 months ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 9 months ago by Carmoney
#1 9 months ago
So my Grand Prix EM works great overall. Previous owner installed a jumper in the backbox for free play. Here's the problem: When you push the credit button, it works perfectly fine for players 1, 2, and 3, but will not activate player 4.
Any idea how to fix this?
Thanks,
Mike
#2 9 months ago
Player stepper Unit not advancing to player 4.
Possible limit switch mis adjustment.
Spring too tight
Sticky.
Spider unit on stepper needs adjustment
#3 9 months ago
phil-lee has the right idea but the unit with the problem is the Coin unit. The wiper side looks like this:
#4 9 months ago
I’ll bet it’s that limit switch. It’s supposed to open at the fourth position I’ll bet it’s bent slightly and opening early.
#5 9 months ago
Quoted from LyonsRonnie1:
Where exactly would I find the limit switch you mention?
#6 9 months ago
If you look in the bottom of the cabinet there is a stepper called the coin unit.... on the one side will be the spider on the other side with the coils you’ll see a switch that opens when the gear turns around it should only open in the fourth position.
#7 9 months ago
Here is a Williams coin unit in reset position. In this position, you’ve pressed the credit button once. The 1 player lite on the back glass is lighted. The switch with the arrow is closed.
When you press once again the credit button, the coin unit advances one step. The 1 player lite on the back glass goes off, 2 players goes on. The switch is closed.
Third time you press the credit button, the coin unit advances one more step. The 2 players lite on the back glass goes off, 3 players lite goes on. The switch is still closed.
Fourth time you press the credit button, the coin unit advances one last step. The 3 players lite on the back glass goes off, 4 players lite goes on. The switch with the arrow now opens.
In your case, the switch probably opens when you’ve pressed de credit button 3 times. Because of this, you cannot add a 4th player.
Adjusting this contact should solve your problem…
#8 9 months ago
I believe Ballycrazy has solved my problem! Thank you Ballycrazy (and everyone else who offered assistance).
I happened to find this video on Youtube:
This provides a video version of the photo Ballycrazy provided, starting around 56:00 on the vid.
I am a different locale this weekend, but when I'm back up there on Sunday, I will attempt the fix and report back.
