Ok high score of 12 Million is ridiculous!! Skills......clearlyI lack.
As for rotation of spinners- I counted and it's absolutely 70 plus on my left and 60 ish right. I have stock game- not even clear coated. But I am anal- my friends tell me- and obsessed over the entire machine on a complete mechanicl rebuild. Every thing that moves was removed and fully disassembled and polished and repaired if needed. I spent a long time (months, but in reality just a few hours) working on the spinners. The trick is you MUST carefully carefully (I digress, but seriously, the piano wire they use is brittle- bend a bit to often and it breaks) adjust the gate holding the spinner and the spinner itself so that it is perfectly stationary as it spins-
This sounds stupid- but carefully watch the ends of the wire that stick out of the gate- they should not move up down or left or right as its spinning- they should appear dead still. Ensure the spinner is not wobbling whatsoever wishing the gate. Ensure that under the play field the switch is aligned such that the point of the wire connecting from the spinner arm to the switch is pointing away from the contacts and that the blade BARELY contacts as the spinner goes over the top. These absolutely RIP when you do this very carefully and lubricate with a single tiny drop of triflo bike lube. It's super fun- it may also be wise to ensure the stepper unit that advances the lights and the score (left and right small steppers) are also emaculate- as this is controlling the score count and light show.
Love the reaction on the random? Through the gap save!
I keep high scores for my kids- my 7yr old boy is at 500K. He loves the "race track" =spinners- and will not play the other games! Good taste I guess!
