(Topic ID: 197751)
Williams Gorgar - High Score Reset
By ClintTarter
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by Gorgar666
#1 4 years ago
I have a Williams Gorgar machine (System 6). I'm having a strange issue. The minimum high score is 500,000. It saves the new high score if you score over 500,000. If you reset the high score it goes back to 500,000. I've tried resetting to factory default and that doesn't help.
#2 4 years ago
What's the problem? 500k is the default high score.
#3 4 years ago
Mine is the same. I switched boards and reset everything and the "new" high score is 500,000. That's normal.
#4 4 years ago
Quoted from ClintTarter:
What are you looking to set your high score at? 500,000 is the default but you can lower it if that is what you are wondering??
#5 4 years ago
Yes. How do you lower the min high score?
#6 4 years ago
In an ideal situation its 0 and goes up from there based on player scores.
#7 4 years ago
Go into the adjustments, #13 according to the manual, and use the start button to change the number back to 0, then reset the high score.
#9 4 years ago
Thanks. Menu #13 worked. Can't set it to zero per the manual but you can set it to 10,000. I don't know how I missed that.
Thanks zacaj
3 years later
#10 1 year ago
How many high scores can be saved? 1?
#11 1 year ago
Just 1.
#12 1 year ago
You would think That the other score Windows would Be 2,3 and 4th. Thanks for the quick answer...
#13 1 year ago
No, that started with the later system 7's. More battery backed ram to hold stuff like that. System 6 was really tight in that dept.
#14 1 year ago
Quoted from slochar:
Thanks for the info...
