(Topic ID: 265421)
Williams Gold Mine display problems
By Arud85
  • 1 post
  • 1 Pinsider participating
    #1 4 years ago
    Hi everyone I have a William's gold mine (shuffle) with a display problem. The game has been sitting in a garage for 20 years and I am fixing it up. It's a system 11b and the game seems to work in every mode but with none of the 7 displays working. I tested my voltages and had 100v dc -100v dc 5v going to the master display board. I rebuilt the high voltage side of the power supply just in case and lowered the voltage. Now I have -92v dc 95v dc 5v dc. I thought I had a bad master display board so I swapped that out with no luck. I looked at the main board and reflowed all the solder joints on the connectors. After doing that I did it on all the other boards just incase and still no display. I inspected for possible corrosion and found a very small spot on 1 diod and 2 resistors but they tested fine. There was no signs of heat damage or burns either. After searching the forum and seeing some trouble shooting ideas I tried them with no luck. I shut off all the lights and looked for a glow but none. The last thing I did was look for voltages on the displays themself and was able to get fluctuating voltages at the displays themselves. So I basically at the point I think the displays are bad but I'm not 100 percent. My question is is there anyone that has any ideas or if someone is in the Connecticut area that I can bring my displays to a working game to see if they work and see if I have a game board issue or a display issue. I'm already looking at getting a pin score setup if i cant figure anything else out. Sorry for the long post and thanks.
    This page was printed from https://pinside.com/pinball/forum/topic/williams-gold-mine-display-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
