Hello,
I am new to working on games, but I'm starting to tinker more and get better. Anyway, the issue I'm having is the right flipper solenoids are real weak on my Flash. They always have been since I bought it. If you hold the right flipper button down, they heat up pretty fast...mostly the bottom one. FYI, The left flipper coil never gets hot...its a little weak tho...not as bad as the bottom right but not good either.
All the flipper coils look replaced. They are blue, I think they were suppose to be orange? Anyway...
Both right coils heat up, but the bottom one was slow to cool where the top right was fast to cool. I ordered and installed a new bottom right coil from Marco and also the corresponding duel contact switch (it was bent up bad)...I went wire by wire to make sure I hooked up exactly as it was there. I left the upper right coil and switch alone. Now, the lower coil has a significant delay before it fires and its REAL weak! Upper coil has the same strength, its ok, but it still heats up a lot and worries me.
The old coil worked, but was noticeably weak and got real hot, I thought the sleeve was going to melt inside, that's why I changed it. The new coil does not get hot...but the delay is bad and its even weaker.
Was wondering if I got the right coil? If all the old coils are wrong. Blown diodes? Any ideas? Maybe the solenoid driver board? I was hoping that replacing the solenoid would do the trick, but it seems worse. I've been reading around and can't seem to find exactly what I'm looking for. Any help would be greatly appreciated...I'm going to include some pics.025.JPG
