I recently bought a Flash in pretty nice condition for $550. Must have been a later production unit as it has the System6 MPU. Previous owner had it professionally serviced. I installed LEDs for the playfield and playfield GI (nat white frosted flat tops, blue frosted flat tops for the guide lanes and drains, blue 8-LED #89s for the flashers). Guide lane plastics were mismatched, so I replaced them with new blue transparent covers. Backbox lighting will remain incandescent.
I decided since it only has 2 flashers, it needed a bit more pop, so I ordered parts to install 6 LED flashers under the cabinet. 8-LED #89s: Blues front and rear, nat white center.
I had the 6 flashers wired in and they were awesome. Got holes drilled in the cabinet, got the front and middle right side and left front flashers mounted. The wiring for the back and middle one on the left side were twisted around, so I unraveled them, tossed the back one to the back of the cabinet. Got the middle one mounted. Decided to power up and see how it looked, got no flashing. ????!!! Worked just a few minutes before. Right side rear was sitting in the hole, left side rear - oh %$#%. When I tossed it to the back, it landed with the + connector arm right on top of the cabinet ground strap. ^%$#$!!! Everything but the flashers work, so I must have roasted a driver chip or transistor. Bad thing is, I can't even find the flashers on the schematic to trace it.
Anyone know which driver chip or transistor feeds the flashers??
