In chasing some odd sound board behaviors, I was checking my ground and power inputs and found something a little disturbing.
I hooked up my scope to check the ripple on the 5 volt supply of the sound board and when the probe got near the metal side rails it showed that there was a fairly large voltage on the rail relative to ground. Using a multimeter it showed 60vAC on the side rail relative to the ground strap.
The ground strap that runs around the periphery of the machine shows zero ohms between the strap and the ground prong on the power plug.
I shoved the multimeter leads into the ungrounded utility outlet in the cabinet and it measured....60 volts. This was the equivalent of measuring across the hot/common of the power cord.
Needless to say the machine is unplugged now.
I checked the wall outlet by placing the multimeter probes in the blade slots and it measured 120v.
I am making the wild and crazy assumption that this qualifies as "not good", but I am not sure where the failure is.
Is there a diagram of the internal wiring between the power plug and the transformer? I have seen snippets of something like this but I have not found the document myself.
Any ideas?
