My 1979 Williams Flash (System 4) that was working recently has started displaying some odd booting behavior and will not start up.
It boots in one of 3 states:
1. Pulsing most coils and about half of controlled lights at about 2.5 to 3 times per second. It's not a full pulse that is strong enough to lift drop targets. GI lamps are on, displays do not show anything or might flash a number or two.
2. Single pulse of coils, then just GIs on. No displays.
3. Just GIs on. No displays.
The MPU board diagnostic LEDs seem to be random. They can be both off, both on, both blinking, or top on and bottom blinking in any of these states.
I'd say #3 is about twice as common as the other two states.
It worked for a while before showing this issue, but had some intermittent periods of starting in audit mode, most likely due to a dying CMOS. This problem showed up temporarily and then resolved to booting in audit mode after reseating most of the cables. Replacing the CMOS chip fixed the audit mode issue and I was able to play several games without issue. Then the display shut off mid-game and I haven't been able to get it to boot properly again. I have tried reseating the cables multiple times and haven't been able to get it working again, so I'm not certain it's actually a cable issue.
All boards are original, and have had all Scanbe sockets replaced with SIPs, remaining sockets are tight enough that I need to use a puller to pull chips, 40 pin connectors/headers are new, all pin headers are new, new CMOS, new capacitors, new remote battery, no visible battery electrolyte damage, about 25% of cable connectors have been replaced/repinned so far.
I'm not really sure what would be causing this or where to start. I'm hoping that someone might have dealt with similar behavior or might at least be able to point me in the right direction. I'm not even sure whether I should focus on the MPU board or the driver board.
An update since I started looking at this: I went through and re-seated all the chips and reseating one of the small chips in the upper-left section of the driver board caused it to stop firing the coils and only blink the lights. I suspect this might be an additional issue I just created, since all other behavior is the same. EDIT - just a blown fuse, coils fire again.
