(Topic ID: 212155)
Williams Flash
By Bernhulk
6 years ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by Bernhulk
#1 6 years ago
Hi Friends ,
my uncle give me this nice Pinball as a present , nobody played it for years and it stand in his Basement .
Last week i put it on all lamps are good and the sound too , i can play it , it works well till i change the batterys (they were too old). The Machine was on when i changed them. I put the Pinball off and on again . After that all lights on the edge doesnt work , only on the playfield (See picture) . Second problem is that the bumpers(Solenoid) dont work anymore and the machine dont give me the ball to play . I think something in the settings are not right . The Diagnostic Mode doesnt Help , Lamps on the playfield are goin not the lamps on the Edge , Bumpers doesnt work , Sound works well.
I Need Help my friends .
Greetings from Germany
#2 6 years ago
Sounds like you got a bunch of connector issues buddy. Not the settings.
Check all the connectors, including the loose molex and the crimps over by the big can capacitor, and make sure they are all in the boards and each other nice and firm. You'll probably have to replace some in the long run.
#3 6 years ago
You Posted this in the EM Tech Forum,
You need the Solid State Forum.
Great Machine!
#4 6 years ago
It sounds like something shorted when you changed the batteries. One of the transistors or SCRs might be bad. Do you have a manual / schematic for the machine? If not, there is one available on IPDB;
http://mirror2.ipdb.org/files/871/Williams_1979_Flash_Manual.pdf
As phil-lee mentioned, post this issue in the Early Solid State forum and we'll meet you over there with some more suggestions:
https://pinside.com/pinball/forum/forum/tech-early-80s-solid-state
#5 6 years ago
If the lamps under the plastics are out those are GI general Illumination. The lamps under number inserts are CPU controlled. Looks like those are on and if dancing in attract mode is a good sign.
Do you know what system board you have 3-6? Yellow flipper roms or Green? As setting in adjustment handbook changed depending on the color.
Post a picture or two of the boards.
Check all fuses for proper value and continuity with a digital multimeter.
#6 6 years ago
Thanks for the Help Friends , i will check it today .
Here a Picture from the system board .
Trade
Machine - For Trade
Woolwich Township, NJ
$ 11.00
Tools
Pincoder Store
2,100 (OBO)
Milan, IL
1,300
Allentown, PA
400 (OBO)
Green Brook Township, NJ
$ 170.00
Displays
Digipinball Shop
$ 9.95
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/williams-flash-7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
