There's one switch behind a rubber that tilts the ball in play. No other switch does this. The switch and wiring is okay and I have new boards. I changed the diode on the switch. Any thoughts?
Quoted from Odessa:There's one switch behind a rubber that tilts the ball in play. No other switch does this. The switch and wiring is okay and I have new boards. I changed the diode on the switch. Any thoughts?
Get the flash light out. Really inspect the switch and all connections for a bridge arc maybe caused by solder ? Follow the wiring look for possible chafed wire. Hope this works out.
Quoted from RobKnapp:Get the flash light out. Really inspect the switch and all connections for a bridge arc maybe caused by solder ? Follow the wiring look for possible chafed wire. Hope this works out.
Thanks for your help. So it probably isn't board related? The reason I ask is a couple of coils started locking on after I had my boards fixed and they weren't doing that before. Could this be related to the switch 'tilting'?
This page was printed from https://pinside.com/pinball/forum/topic/williams-firepower-switch-tilts-ball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
