So I recently got a williams firepower and it will turn on and the flippers work. After turning on and seeing a few backglass lights nothing else happens. You can clearly see some battery damage and I am pretty certain a couple of boards need to be replaced. I am totally a newbie when it comes to pinball parts so please excuse me not knowing what anything is called whatsoever. The board with the Rom on it and batteries on it seems damaged. Also the board below it. (interconnect board maybe) which is connected to it by a long connector across the top. The right two boards (power board, and sound board I believe look to be good. Also the scoreboards seem to be good but just not working because of the bottom board I referred to I believe. I can smell something cooking when it is powered on as well and it seems to be coming from that same board. So if it sounds like a good idea I believe I need to replace those two boards, and then possibly the playfield. I would rather get it working before I replace the playfield though. If someone has these parts or knows where I can get the best price online somewhere, let me know. Thanks!
