Quoted from brothersun:On my Firepower II, when a ball drains, instead of the ball being kicked up the next ball staging ramp, it just sits there. If I bang the cabinet eventually it will kick.
But the strange thing is that when I do a switch test, the switch works fine. It only fails during game. I tested the diode and it works. I also checked to see if other switches on the same matrix row or column are working and they are, so it's not a row or column problem.
Few questions....
When you bang the machine to get the outhole relay to kick out the ball into the shooting lane does it drain the bonus as it should?
Does this happen for every ball?
Does the outhole relay fire on?
Does the outhole relay fire on and the ball doesn't come out?
When you trigger the outhole relay switch with your fingers to get the ball to kickout are there any other relays that kick on?
Here is the manual for the game. https://www.ipdb.org/files/857/Williams_1983_Firepower_II_Operators_Handbook.pdf
Page 5 of the manual says to place 3 balls next to the outhole to run diagnostic test. I'm not exactly sure why but it does say this is important. I skimmed through the rest and there is a section on diagnosing and running tests.
Hopefully you replacing the switch will fix it!
