I'm having a weird issue with several backbox lamps pulsing or strobing when I turn on the game. The problem seems to be on the driver board, as I currently have this driver board in Firepower, but when I put it in Gorgar, it does the same thing. In this video, you can see that the P2, P3, P4, Tilt, Shoot Again, and other controlled lamps start flashing as soon as the game is turned on, and continues when a game is started.
I've switched out the lamp matrix PIA as well as the 7408 IC 14 since it seems that most of the lamps that are flashing are from column 8. The driver board has had the 40-pin board interconnect connectors replaced, as well as new sockets for the PIA's.
Anyone else ever see something like this, or have any thoughts on what to check next?
