Hey guys, just picked up a Williams Fire! and after a few plays it starting giving a switch warning for the upper right slingshot. I was not able to get either switch to register in test mode and the coil would not engage in the solenoid test. The opposite kicker on the left would score, test fine in switch and solenoid tests. Upon further investigation, the coil was not mounted correctly, the diode was essentially against the coil stop. The coil was fried. I replaced the coil with no change, the coil does not lock on as I suspected it would.
I pulled the board to find that this section appears to have been a problematic area in the past. I understand why the coil is burnt and the it will not fire, but I do not get why the two switches at the right upper slingshot do not register. They both look fine, no broken wires, etc. Was hoping someone here could shed some light on why. The only thing I can think is that maybe a previous owner disconnected the switches or cut them somewhere that I haven't found yet. It seems like too big of a coincidence that the coil is fried and both switches do no work.
