Hi to all of you! I have an issue in my Fire pinball...all coils are weak in gameplay and in test mode...can you help me to resolve this kind of issue?
Thank you
Thank you
Quoted from Misterpink:all coils are weak in gameplay and in test mode...can you help me to resolve this kind of issue?
Check the voltage coming off of the bridge rectifier. Should be @ 34 volts DC.
Quoted from GRUMPY:Check the voltage coming off of the bridge rectifier. Should be @ 34 volts DC.
The voltage coming off the bridge is 25 volts DC. I forgot to tell when the pinball is wamed up, coils have power
Quoted from Misterpink:The voltage coming off the bridge is 25 volts DC.
Check the input side of the bridge. This will be the 2 red wires. It should be 26 volts AC. If the input is good then replace the bridge rectifier. If the input is low then check the connector down by the transformer. The connector may be loose or have burnt pins.
This page was printed from https://pinside.com/pinball/forum/topic/williams-fire-all-coils-are-weak and we tried optimising it for printing. Some page elements may have been deliberately hidden.
