Need some help on a Williams Fan-Tas-Tic. I’ve gotten almost everything under control. This has me concerned. Ball in the kicker hole spins the wheel, wheel spins and stops, scores whatever it lands in (so far so good) then one of 2 problems might happen. Sometimes the ball doesn’t kick out. Sits in the hole for 5-10 seconds then the wheel spins again, scores and usually kicks out. The other issue that might happen is that everything works correctly, ball kicks out but if it’s hit back in quickly (or placed in by hand for testing purposes) it will sit for 5-10 seconds and then the wheel will spin. It seems that something has gone wrong with the electronic delay timer. Any time the delay is activated, you can listen for about 10 seconds and then hear the click when it releases. During the “dead time” waiting for the wheel to spin, If I force the delay relay open by hand, it spins immediately. I’ve ordered a new capacitor, resistor and transistor just in case.
Is there anything else that should cause the delay relay to release sooner?
I’m also having issues with the 50 point rollovers. They score randomly from 0-50 points. I did adjust the gap on the 50 point relay and it made it score correctly except it also started scoring in the outhole, sometimes multiple times.
I’d appreciate any thoughts on these issues. Thanks
