(Topic ID: 257676)
Williams Dracula - Left and right gate not working - Suggestions?
By Barakawins1
71 days ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 69 days ago by Barakawins1
#1 71 days ago
Trying to get the mist multi ball to work. I changed sender/receiver optos. Now they see each other. In switch test I can see them register when my hand passes
the beam. In magnet test I never get the left or right gate to open. I tried solenoid test and the left and right gate does not open either. Can someone advise what I'm missing with respect to these gates? I doubt both solenoids don't work to open the gates.
#3 70 days ago
Check the connectors and ribbon cable on the fliptronics board. Interestingly, the left and right side gates, along with a few other solenoids, are controlled from the fliptronics board.
#4 70 days ago
Interesting. Thank you for that info. I’ll report back
#5 69 days ago
OK.. so now we have gates working. Crazy enough, no fuses were installed.
#6 69 days ago
Quoted from Barakawins1:
That'll surely do it. Gates must not have worked for a while if that was the case.
#7 69 days ago
Crazy.. but I never thought of the fliptronics board. So I got the gates working and the magnet would not energize in Magnet test. I checked the wiring harness
and sure enough, the phone wire style harness had a broken wire.. Fixed that with solder and heat shrink. Wrapped the area with electrical tape for reinforcement
and voila! All works now!
Thanks for the heads up schudel5
$ 109.99
$ 159.99
$ 5.00
4,500
York, PA
