Hi freddo30, Dr_Nybble +
I agree with Dr-Nybble: Daisy-chained Zero-Position-Switches (Score-Drums) come together as ONE wire-blue-brown - comes to JONES-Plug, then going down into the Cabinet and to "Self-Hold-Switch on Reset-Relay". And this needs a careful inspection.
From the fact "ALL 16 Score-Drums have the fault": I clue "not very likely fault(s) on Score-Drim-Zero-Position-Switch". I say (see written above) --- see JPG: "Red line" - THERE You have a wire broken-off from a Solder-Lug - wires are stiff, they stay in place (sometimes) --- a bit of shaking and the broken-off end moves away a bit - NO connection --- a bit of shaking - connection again.
I believe (please look-up in the pin): On the Switch on Reset-Relay TWO wires-blue-brown are soldered-on - ONE is good (the connection to Score-Motor-Switch-IND-C) and the OTHER one is bad: The connecting wire up - through Junes-Plug to Score-Drums-Zero-Pos-Sws.
freddo30, You +/- write "ALWAYS ALL Score-Drums reset (means stepping forward) to 6666 6666 6666 6666. To support my theory: Look at JPG at text "shown again" - see (?): The turning
Score-Motor does open-again (closed) SCM-IND-D VERY LATE (at the very end of a turn) - the "good stepping to 6666" actually is done BECAUSE the Reset-Relay is FEEDED through "my green wiring" - through the SCM-IND-D CLOSED for (almost a) complete turn.
Look, write - we may want to use a Jumper-Wire to jumper exactly "my marked red" line, greetings Rolf
